Hi all,
I have a ePMP 1000 connectorized NON-GPS radio used as a backhaul.
This radio is connected to a Mikrotik router.
Now my problem is that this link at the end of the Client end is connected only at 10mbps full duplex instead of 100 mbps.
Both the network ports of the radio and mikrotik are set to auto-negotiate.
At times, the link gets connected at 100 mbps full and works for days but then goes down to 10 mbps.
On the mikrotik router, the status shows the Link Partner Advertising only at 10M half and 10M full.
This mikrotik router has both 100 mbps and 1000 mbps ports. I tried changing the ports but this does not help.
This radio is located on a FM radio tower. Could this be the problem or this is simply a case of a bad cabling?
Any help will be appreciated.
Regards,
Sanay
