Dear All hai I am from SbInfotech from India
I have face the problem in ePMP1000 device autometic Hardware reset please share this tipe problem any up date me
Dear Sadanandam,
Reason this might happen is due to power fluctuation.
Please check under Tools--> Backup/Restore --> Factory Default Configuration --> Enable/Disable.
As default this will be Enabled. Make sure this is Disabled and there is a stable power supply/backup.
Anand.
