In reference with attached screen short
Why is it that epmp 1000 doesn't save the configuration if you choose disable auto channel selection,and it only allows to save if you select on automatic channel selection
Could you please attach screnshot you are referencing to?
Thank you.
Hello Francis,
Make sure you select a Frequency Carrier right after disabling ACS.
Regards
