The Force-110 antenna gain is 25dBi. For short range PTP and as SMs, that's fine. I need longer range capability for PTP links, 10+ miles. Make a 2' parabolic (compatible with Laird radomes, and/or just OEM the HD-DA5W-29DP) and give me an integrated connectorized ePMP radio mount. Call it the Force 120, or maybe 200.
they have mount stuff
this is from winncom
http://www.winncom.com/en/products/N000900L006A
you can use any antenna with rp-sma connectors.
i would use the sync units on a link greater than 10 miles.
Connectorized ePMP units can be fitted with many ecosystem choices, ePMP Force 110 is retired.
