I understand that, I'm trying to figure out how customers can vary from -17 to 30 degrees vertically, and why there appears to be no correlation between customer distance from AP and the vertical angle.
In ordinary circumstances with fairly flat geography - as this AP serves - I would expect more distant SMs to be consistently higher angles.
For a sector 250ft up a tower with about 5 degrees downtilt I can't see how there can be a 45+ degree variance in vertical, customers are all between 1 and 8 miles from the tower.
Is it better to mount the smart antenna directly to the sector antenna so down tilt are identical on both antennas? Or, is it better to mount the smart sector seperately so you can adjust the downtilts as needed?
