ePMP 2000 GPS Upgrade Stuck
Attempting to upgrade ePMP2000 GPS to AXN_5.1 and the AP appears to be hung up.
On attempted login I see the message "ePMP 2000 SW Upgrade is in progress"
I've waited almost an hour.  Checked the subscribers and all are up.
Will any damage occurr if I power cycle the AP?
Command line "show syslog" indicated that the gps upgrade was complete so I rebooted the radio.
After reboot "Monitor GPS" shows it tracking 20 satellites.  System status shows GPS Sync up.
Everything seems to be ok
