Hi there! I have a problem for the smart sector after my radio is up from 3.5.6 to 4.3.2
smart antennas are often disconnected and the client is connected to all antenna sectors, it makes the client connected to the ap experience quite a problem, for now my smart sector is disabled and forced into the antenna sector,
is there anyone experiencing this kind of disturbance?
Hi. Is this ePMP2000 used in Compatibility mode with Force 300 clients, or are the SMs all Force 100 / 180 / 190 / 200s?
If its just all ePMP 1000 / 2000 series, then I’d recommend you use 3.5.6 with your ePMP2000 and ‘n’ clients.
If you need mixed ‘n’ and ‘ac’ compatibility, then I’d recommend you skip 4.3x and go to the latest 4.4RC or 4.4 Release very very soon.
However, the BSA support is still a ‘future feature’ in Version 4.5 as far as I know. So, if you don’t need Force300 compatibility, 3.5.6 would be your best bet for now.
