Can the 450b Retro Subscriber Modules be used with the ePMP 3000 AP?
No. The 450 line and the ePMP line are incompatible with each other.
Can you name some compatible subscribers?
Thanks!
Assuming you’re using an ePMP 3000 AP, any of the Force 300 Series Subscriber Modules on the ePMP product page.
So I assume the C050045A202A - PMP 450 Micro POP 5GHz AP is fully compatible with the 450b subscriber module.
Yes, that is correct.
Hi @Javier_Olivera We have many options to use with E3K. It is better to contact you local dealer to see what is available in you region.
