EPMP 3000 beam forming antenna vs 2000
Hello a simple question:
I have EPMP2000 systems with panel antenna + uplink antenna.
I would like to replace it with a EPMP3000.
Can I use the same uplink antenna?
thank you
Yes… it’s the same antenna… however it won’t be supported in software on the e3k until possibly release 4.5.
