Hi, what are the IPs to access to this device?
In the old series I comfortably had 169.254.1.1, but with this IP it doesn’t work.
Obviously connected to the poe port…
Thank you
Thank you
Default and Fallback IPs remain the same.
169.254.1.1 and 192.168.0.1/192.168.0.2 for AP/SM accordingly.
Thanks.
The problem is that as soon as I start it I notice that it makes about 10 pings, then it starts to time out for no reason… always connected to the eth poe port
Hi @wispone,
did you pay attention if it reboots according to indication?
I suggest to contact support. “Raise ticket” in the right top of this page.
Our engineer will assist to sort it.
