Does the 4600 split sector setting allow for a front to back setup? If so will that hinder or help the ability to do MU-MIMO once the FW supports MU-MIMO?
Yes, it does.
Thank you.
Will it help or hinder MU-MIMO once it is available?
If you’re using the 4600 for 2x2 front and 2x2 back, then MU-MIMO will not work.
That is what I thought would happen, but I wanted confirmation.
