I am using the 600SSH surge arrestor with an ePMP integrated. The unit powers up, but it does not get data through. I cannot even ping on the ethernet. I have tried multiple surge arrestors, all new, it does not solve the problem. Remove the surge arrestor and everything is fine, so the radio itself surely is fine. We've also tried changing cables as well.
When you swap out the cables, being there would be 2 RJ45 ends, do you connect the two ends together or are you testing the one cable to the radio to get it to work? Is the 600SSH grounded for your testing? The first thoughts come to mind being you swapped out both the surge protectors and all the cables is if you at least see link on the end device or somewhere in the testing the Tx and Rx pairs are getting reversed. Another thought is if it is grounded, possibly the ground is bad and introducing noise.
If you are using the 600ssh and you can't ping your device, open suppresor box and move the pin from 'isolated' postion and move to 'ground' position. Also keep in mind if the installation requires 1 Gbps then you need to swap out suppressor and use AL-CAT6HPJW.
If you\'re using the 600ssh IN ADDITION TO anyone are unable to ping your current device, open suppresor field ALONG WITH move your current pin via 'isolated' postion AS WELL AS move to be able to 'ground' position. in addition don\'t forget if your own installation requires 1 Gbps and then you\'ll want to swap out suppressor IN ADDITION TO EMPLOY AL-CAT6HPJW.
