Anyone have this issue where you cant login into the unit web gui? Seems to have appeard to happen after firmware 2.5.1 upgrade. It only appears to happen with its loaded up with CPE. This particular one has aprox 60-70 CPE connectrd to it.
If there is no one connected its fine if there is 30-40 its fine but as more CPE get on and traffic flow is higher I am unable to log into it. I can get the username and password screen and enter my inof andtry but it just sits there VERY VER VERY rare I am able to get it to login in and when I do its like a windows PC and the CPU is being used up by lots of processes VERY VERY VERY slow to respond.
Other AP's on this SAME router and network are fine but then again they only have about 15-20 CPE connected.
I upgraded to 2.5.2 and it took allnight to upload and hugn at the reboot process. I was able to login to the AP this morning while traffic was slower and it said the firmware was succesful and a reboot was require so I did so manually. Its back up so we will see if this does anything. I did not see anything in the release notes about this issue specifually. Supports respones was log in locally and try if not reboo t and try if not then firmware upgrade if still having issues call us back.
Really not much help since I have tried all but upgrading FINALLY.
Is there a way to check CPU usaage or SNMP to do so? I think its CPU overload and cant handle this amount of traffic?
