Use the Radio page to configure the device radio interface parameters. This post will focus on the Advanced attributes available in standard WiFi mode.
Advanced
RTS Threshold |
Configure the RTS packet size threshold for uplink data transmission. Range is between 0–2347 octets. Typically, sending RTS/CTS frames does not occur unless the packet size exceeds this threshold. If the packet size that the node wants to transmit is larger than the threshold, the RTS/CTS handshake gets triggered. Otherwise, the data frame gets sent immediately. |
