We have been having an issue where an ePMP 2000 only has a 100Mbps Ethernet status when it should have a 1Gbps Ethernet status. The 2000 isn’t flipping between 100Mbps and 1Gbps it says at 100Mbps all the time. The issue is not the cable connected because we tested the cable with an F200 radio and it said 1Gbps Ethernet status. We are using a Netonix switch that has flow control connected to the 2000. Has anyone had a similar issue with the ePMP 2000 or have any idea what might be causing it?
Have you tried toggling ‘Smart Speed’ on the AP’s network page?
I’d also avoid using flow control… it often times causes more problems then it solves.
