Hi;
Is it possible that the Force 110 parabolic dish antenna can work without the following pieces:- 1) the grid antenna, i.e. the wire piece that is in the front and snapped on. 2) the center ring to the very front (not the feedhorn).
Due to Category 3/4 wind speeds, the Force 110 doesn't hold up. Either the feed horn blows off or the grid piece blows away like a discus, or the plastic holders that snap the grid to the main solid dish separate.
Also, the Force 110 dish tends rust very quickly. Resulting in rust stains dripping on the clients rooftops.
In the attached photo, it is missing the feed horn. I'm referring to the other piece.
Also, are those pieces if damaged, lost during severe wind etc. replaceable by ordering individually? If so, what would those reorder part numbers be and most likely source or place for ordering?
Most likely one may just have to reorder the Force 110 dish kit again in order to use the ePMP connectorized model. Or, just upgrade to the ePMP Force 200.
- 20161026_114440.jpg (3.11 MB)
