Am i able to connect my mobile hostspt to my epmp force 300-19r in SM standard wifi mode
It is not possible it working only ePMP to ePMP
Sir can’t it be used in force 300 19r
No. There is no such functionality in F300 series and it is not planned.
Can we connect mobile hotspot to cambium epmp 1000 and then can we broadcast or establish AP and then can we connect through epmp force 300 19r
I don’t think I understand your question.
Please draw your schema or tell what solution do you need to build.
First of all my friend has unlimited data in his mobile phone who is located 6 km from my home
Now my plan is that if i place epmp 1000 at his home now my first question is that
Can my friend able to connect his mobile hotspot to epmp 1000 as AP then is it possible to broadcast his mobile data through this epmp 1000
After that in my home i will place epmp force 300 so now my second question is am i able to connect that network which will be broadcasted by my friend
Here i am talking my friend as AP and me as SM
Or else tell me other ways to handle this using my epmp force 300-19r
Sir please reply me i want solution to this problem
You can get one more F319 to form a wireless bridge over your distance. But you need somehow to inject the connection from the mobile into this link.
You can take any wi-fi router to get wi-fi network from the smartphone and then connect lan port to Cambium bridge. Or find some router that can connect mobile network with a sim-card.
But it sounds costly and takes a lot of effort. Is not it better just to buy one more mobile contract for this budget?
I thought the same thank you sir
