ePMP Forward and Backward compatibility rules
They will connect and pass data, but it is always recommended to run the same firmware on both AP and SM for stability puposes.
Dmitry
planetcaravan said:
>What about bacward compatibility if AP
>is 4.4.2 (ePMP2000) and CPE are on 3.5.6?
In my opinion, that’s asking for trouble. It may work fine in some situations, but that’s playing with fire as far as I’m concerned. :slight_smile: If the AP is 4.4.2 then I would have all SMs as 4.4.2 as well.
Hello i was trying a link with force 300 and force 200 29km,
I will install other force 300
Looks like you’re trying to use ePTP? I think someone mentioned that ePTP is not compatible between different ePMP generations.
Yes i used eptp but here in mexico told me that they are compatible !!
But not
Dont wasted the time trying that !!
Yes, unfortunately ePTP mode isn’t compatible between generations for some reason. You should be able to use TDD or TDD PTP mode though. That’s no a perfect solution, BUT it’s a good solution to allow change one side of the link at a time.
ALSO - for us - at 29KM, we’ve found that TDD Mode has actually worked better than ePTP mode on our Force300’s. Your mileage may vary, but we found that under load and at distance, the Force300’s ePTP mode didn’t hold up like the 1000/2000 series does. We’ve been very pleased with TDD mode however. But, I’d be eager to find out your results.
Well, I will install the other force300, thanks for ur advice about TDD, i will reply tomorrow the result of this link, 29km the client only needs 10-15mbps
Thanks bro
Regards
Well i have done this link 29.645km with 2 force 300 -72-73, 4up/16down, eptp mode
It would be interesting to see what it does in TDD PTP mode 75%/25%. I mean, the signals are barely functional, but I’d be curious to see anyway.
Hi all. Is there a new chart like this with inclusion of the AX products?
Thanks!
