maxwire
(maxwire)
1
Ive searched high and low, I found it for 450 (1.3.6.1.2.1.10.7.2.1.19.1 if anyone was also looking)
For EPMP all I can find is OID for the configured state, not for the actual state.
Is it just not a supported SNMP metric? I could really use this. Im limited to SNMP since this is a Powercode specific need
MW_WISP
(MW_WISP)
2
Do you mean
.1.3.6.1.4.1.17713.21.3.4.2.11 or CAMBIUM-PMP80211-MIB::networkLanDuplex?
snmpget -v2c -c MyCommunity x.x.x.x CAMBIUM-PMP80211-MIB::networkLanDuplex.0
CAMBIUM-PMP80211-MIB::networkLanDuplex.0 = INTEGER: 1
networkLanDuplex OBJECT-TYPE
SYNTAX Integer32 (0|1)
MAX-ACCESS read-write
STATUS current
DESCRIPTION
"LAN Duplex Mode
0 - Half,
1 - Full
Device Allocation: AP, SM"
DEFVAL { 1 }
::= { networkLan 11 }
edit: maybe this is, like you said, the configured state. Sorry
maxwire
(maxwire)
3
Yes, its the configured state. I dont know if theres a get format that will result in the state using that OID though
