Currently we are using mrtg to graphs RRSI,Data usage,Latency and color code for our cambium SMs like 450 and FSK, and mrtg is graphing all data perfectly.
Now we want mrtg to graph same objects for ePMP SMs as well but having some difficulties, can somebody please expliain how can i do that and what MIB files and OIDs i need to use.
my current configs are as following, these configs are only printing Latency graph other 3 not printing.
#Color Code Target[10.10.7.53colorcode]: 1.3.6.1.4.1.161.19.3.2.2.65.0&1.3.6.1.4.1.161.19.3.2.2.65.0:Canopy@10.10.7.53:161::::2 Directory[10.10.7.53colorcode]: 10.10.7.53 MaxBytes[10.10.7.53colorcode]: 125000 Title[10.10.7.53colorcode]: Color Code PageTop[10.10.7.53colorcode]:<H1>Color Code For 10.10.7.53</H1> Options[10.10.7.53colorcode]: gauge, growright, expscale
#Radio Signal Strength IndexFor 10.10.7.53 Target[10.10.7.53RSSI]:radioDbm.0&radioDbm.0:Canopy@10.10.7.53:161::::2|string2int Directory[10.10.7.53RSSI]: 10.10.7.53 MaxBytes[10.10.7.53RSSI]: 125000 Title[10.10.7.53RSSI]:Radio Signal Strength Index For10.10.7.53 PageTop[10.10.7.53RSSI]:<H1>Radio Signal Strength Index</H1> Factor[10.10.7.53RSSI]: -1 Options[10.10.7.53RSSI]: gauge, growright, YLegend[10.10.7.53RSSI]: -Decibels ShortLegend[10.10.7.53RSSI]: LegendI[10.10.7.53RSSI]: In: LegendO[10.10.7.53RSSI]: Out: Legend1[10.10.7.53RSSI]: In Legend2[10.10.7.53RSSI]: Out
thanks for your explaination, i never dealt with snmpwalk and i tried creating config files using configmaker but did not got my results beacause i have 2300 device for mrtg to print graphs, so then i used seperate config files for each device using "Include" command, and it's working fine for cambium 450's.
I think i am not using right OID and MIB files for ePMP.
