I am working for some project : harbour, boat, trucks, stand alone PTP on a mast, ...
I need to have some autonomous system for ePMP 3000, 300, 200.
Can we build a cable to powering the radio with 12, or 24, 48 volts from a group of batteries ? i think, i need a DC/DC converter to regulate the voltage.
I have tested the F180 with a battery 12V, connected with a jack in a passive injector. it's OK.
But, what about for the others ? It seems to me, that is 30V for these 3 radios.
But, If i have a very short cable, perhaps 12 or 24 volts is ok ?
I don't know what is the real voltage for the hardware inside. For example, if i have 10 m between the radio and the power battery, it's ok for 12 or 24 V ?
The 3000 will run fine off 48v for up to 100+m using CAT5e, the 300 will run fine using 24v up to 100+m using CAT5e. We run both off Netonix switches, and those are the voltages (24 and 48) Netonix offers.
Here is a quick drawing with parts list of how I would -possibly- wire the SM's.
