Justin_3
(Justin_3)
1
Is there an OID for the "Reset via Power Sequence" Setting under Tools->Backup/Restore?
I can't find it in the online MIB docs @ http://support.cambiumnetworks.com/framed/onlinetools/
I need to shut this feature off to over 200+ AP's, and doing this manually would not be desired.
Thanks!
Justin_3
(Justin_3)
2
I might have found this on another post:
snmpset -v2c -ccommunity 10.12.12.3 .1.3.6.1.4.1.17713.21.3.6.1.15.0 i 0 (To disable)
snmpset -v2c -ccommunity 10.12.12.3 .1.3.6.1.4.1.17713.21.4.4.0 i 1 (To Apply Settings)
Please disregard,
Thanks!
