ePMP Sector Antenna, 5 GHz, 90/120
What about Cambium ePMP Sector Antenna, 5 GHz, 90/120 in high interference environment?
Assuming that you use this antenna with an ePMP 2000 and the optional BSA, then this can be an excellent option for a high noise site. If you don't plan on using the BSA, then using RF Elements horns (like the 30 to 60deg) can be an excellent way to further avoid noise.
Eric,
actually I work in kabul afghanistan with huge amount of FR interference. a small city with 34 WISP running.
I have worked a lot on UBNT products and I declare ubnt fail in kabul Afghanistan. now switced to cambium.
lets see how cambium deals with this interference.
will upate you
Strikewaves
