Use the SM Traceroute page to display the route (path) and associated diagnostics for IP connectivity between the SM and the destination specified.
Attribute |
Meaning |
Traceroute |
IP Address |
Enter the IP address of the target of the traceroute diagnostic. |
Fragmentation (-F) |
ON: Allow source and target to fragment probe packets. OFF: Do not fragment probe packets (on source or target). |
Trace method (-l) |
ICMP ECHO: Use ICMP ECHO for traceroute probes. UDP: Use UDP for traceroute probes. |
Display TTL (-l) |
ON: Display TTL values for each hop on the route. OFF: Suppress display of TTL values for each hop on the route. |
Verbose (-v) |
ON: ICMP packets other than TIME_EXCEEDED and UNREACHABLE are displayed in the output. OFF: Suppress display of extraneous ICMP messaging. |
Traceroute Results |
Displays the results of the traceroute diagnostics. |
