Good day my device firmware is not updated above 1.4.4 how to solve this problem?
Alexander,
You may download ePMP software here: https://support.cambiumnetworks.com/files/epmp
This link will allow you to download software up to 2.0.2.
Click on the Tools menu --> Software Upgrade button to upgrade your radio.
If you would like to try Beta software on the ePMP product you can use the same link as above. The Beta software has a new GUI and some new features. The beta software is currently up to 2.1RC29.
Good day, downloaded the firmware for the link that you provided. When the firmware update do everything exactly as you describe. The problem is that when you upgrade the firmware loses the connection to the device. After 5 - 7 minutes of connection to the device is restored. But the old firmware version.
