ePMP1000 auto reboot
Hi, they wanted to comment that restarts AP ePMP1000.
I found the following log.
Source Sync: CMM3
[Message Details] crond[1843] time disparity of 336380 minutes detected.
Someone can tell me what is happening???
Source Sync: CMM3
i didn't completely follow your question, the time disparity is the difference of the internal clock and the NTP server, that number will slowly grow over time as the default time and real time get further apart, it in itself isn't a bad thing.
if your looking for more information in the log, download it and open it, or send it to a logging server, the in gui display is limited.
Thanks you responce, that time difference restarts? This configured with a rsyslog It is configured with a syslog, and after this message the AP is reset.
Thanks.-
its just the clock getting set, they don't retain time when they are powered down.   nothing to worry about.
Thanks Chris_Bay
