ePMP1000 vs ePMP3000L
Hi all,
we are considering replacing ePMP1000 with ePMP3000L to give a little boost on smaller areas. We know that 3000L has the subscriber limit to 64 at the momenth and thats ok, but in performance/hardware view is the 3000L better than a 1000 even if we connect only Force200/180 CPEs?
Hi @vmiskos,
take a look at this:
http://community.cambiumnetworks.com/t5/ePMP-3000-2000-and-1000/Introducing-ePMP-3000L/m-p/102413
Hi vmiskos,
You should see a benefit in 40MHz channels and less benefit in 20MHz channels. Also it will allow you to connect F300 SMs using higher modulations.
Dima M
thanks @Tommaso
@Dmitry Moiseev thank you for the answer. Less benefit on 20MHz you mean 3000L will still be slightly better than 1000 right?
@someone wrote:
thanks @Tommaso
I think what Dmitry is saying is that at channel widths greater then 20MHz, the 3000L will perform better, I assume this is due to better PPS processing capabilities. You'll also have 256QAM modulation levels with the 3000L as well (when used with AC clients of course).
