The ePMP 2000 Access Point with Intelligent Filtering and Sync interfaces are detailed below:
Name |
Connector |
Interface |
Description |
Antenna port H |
RP-SMA, female |
Antenna, |
To/from H polarized antenna port |
Antenna port V |
RP-SMA, female |
Antenna, |
To/from V polarized antenna port |
Smart Antenna port H |
RP-SMA, female |
Smart Antenna, H polarization |
To/from H polarized Smart Antenna port |
Smart Antenna port V |
RP-SMA, female |
Smart Antenna, V polarization |
To/from V polarized Smart Antenna port |
Ethernet |
RJ45 |
PoE input |
802.3at-compliant Please note: A non-802.3at-compliant power supply may also be used to power the device. The power supply must supply at least 20 Watts. |
10/100/1000 Base-TX Ethernet |
Management and data |
GPS |
SMA, female |
Antenna, GPS |
To/from GPS antenna |
Reset Button |
Physical button |
N/A |
For resetting the radio and for setting the radio back to its factory default configuration. |
LED |
Function |
PWR |
Green: Power is applied to the device Unlit: No power is applied to the device or improper power source |
GPS |
Orange: AP has acquired a 1PPS GPS synchronization pulse either from the internal GPS module and antenna or from a connected CMM Unlit: 1PPS GPS not acquired, or Synchronization Source set to Internal (AP operates without sync) |
No LEDs lit: Three or less satellites tracked One LED lit (top): Four or five satellites tracked Two LEDs lit (top two): Six or seven satellites tracked All LEDs lit: Eight or more satellites are tracked |
ENET |
Once lit, blinking indicates Ethernet activity Red: 10BaseTX link Green: 100BaseTX link Orange: 1000BaseTX link Unlit: No Ethernet link established |
