[ePMP2000] Can the Smart Antenna be used with 3rd party antennas?
The Smart Antenna and the Sector Antenna do not share any dependencies, allowing for usage of 3rd-party antennas.  A pole-mount adapter is available for the Smart Antenna which allows operators to mount the unit independently from the sector antenna in use.
