I would like to know which is the maximum Gain that we can obtain with the Smart Antenna of the ePMP2000. I need to know also the Beamwidth in the Horizontal and Vertical plane of this atenna.
Regards.
Regards.
@smartinez wrote:
Regards.
Smart Antenna gain is comparable with Antenna Gain of Sector Antenna.
Smart Antenna has effective coverage in 90 degrees Azimuth and 180 degrees Elevation.
Smart Antenna dynamically forms beam for each specific case.
Beamwidth of each beam is approximately ~15 degrees in Azimuth.
Thank you.
