ePMP2000MapMissCounter, what is its significance?
I have two ePMP 2000’s deployed, one with just a sector, the other with a sector and smart antenna. I monitor their stats via the CLI. In show wireless the metric ePMP2000MapMissCounter on the AP without the smart antenna is significantly higher than that on the AP with the smart antenna. What does this metric mean? And should I be concerned?
I have attached the graph of the non-smart antenna AP’s last seven days of this metric measured as delta’s from the prior 5 minutes.
Hello Nate,
You can ignore this statistic for a ePMP2000 that is not equipped with a Smart Antenna. It is associated with the communication between the ePMP2000 and the Smart Antenna, and mostly for troubleshooting purposes.
Regards
