I would like to have the radiation pattern file (adf or other format) of the sector antenna of the ePMP3000 (C050910D301A) to load it in the software I use to make the coverage calculation.
In adition, if you could provide me the radiation pattern of the new dual horn antenna, it will be very usefull.
Thanks in advance.
Regards.
Does anyone have these antenna pattern files?
