hi,
It's possible connect more than one ePTP Slave in one ePTP master ? or in PTP TDD ?
hi,
Hi Alex,
PTP abbreviation you see in mode names ePTP and PTP TDD means Point-to-Point.
Only one SM in ePTP Slave mode can be registered on AP in ePTP Master mode and only one SM in TDD mode can be registered on AP in TDD PTP mode.
Thank you.
Hi Fedor;
Just for further information on the ePTP mode.
Regards.
Hi Lincs_Chel,
SM in ePTP Slave mode can be registered only on AP in ePTP Master mode.
AP in ePTP Master mode cannot hold more than one SM.
GPS sync is supported only in TDD mode.
Thank you.
Hi Fedor;
Thanks very much for explaining this further.
Sometimes, it appears from the documentation and users comments that you can have an ePTP slave or ePTP mode on a single SM in the same sector just to satisfy a low-latency customer or for a micro-POP or micro-cell setup/application. While at the same time having regular SMs associated to the same AP.
Maybe a warning or popup note on the AP that says that this is exclusively for establishing a Point-to-Point mode may help. Like when you hover the mouse of the various mode selections may help.
