I have a client who wants a small evenly populated site covering an area of about 5KM in radius to be on seamless internet wireless throughout the compound so that wherever you walk you get internet and you dont need to even change your password. Which equipments can you suggest to achieve this solution. Thank you!!..
Hi Richard, That will depend on how your planning your backbone.
What mounting assets will you be using to deploy the access-points?
Will this be indoor and outdoor coverage?
Are you looking to support VoIP, Video and/or just Data connectivity?
In regards to your question about deploying our ePMP product line it would depend on how your setting up your backbone connectivity to the distribution layer (access-points) if the deployment area will have a wired ethernet cable connection at each deployment/mounting location then there would be no need to use our ePMP solution.
Kevin Tyler
Regional Technical Manager
Cambium Networks
you will first the point where the fiber lands.
Then, there is a need to do point to multipoint links with the ePMP or PMP 450i micro Pop to connect other building and then have Wi-Fi from those buildings.
To build the Bill of Quantity, there is a need to work with LINKPlanner.
