Good evening everyone. I need some advice. We currently want to upgrade our 600 Mbps connection to a 1 km radius. We have a Mimosa router, but lately it’s been having a lot of problems. It would be very helpful if you could recommend replacement equipment. Thank you in advance.
There are multiple options available.
What are your spectrum preferences?
2 epmp as PTP 4625 will make it
In the 5.9GHz to 7.1GHz range, the first option is the Force 4625. Do you have any other models in mind?
The 4600C can deliver throughput of up to 2 Gbps and serves as a premium option compared to the F4625. The F4600C supports higher modulation levels, features a more powerful CPU, and includes a built-in GPS module and an SFP+ port.
