Hello ,
I am configuring some e410 access points and I get the following error:
Error Not In sync configuration failed:radio1_drf_num_per_samples:specified parameter greater than maximun
How can I solve that
Thank you
Hello ,
Thank you
@Fractalia
Please upgrade your AP to cnMaestro recommended version and try to sync the configuration, should help you to fix the issue.
Upgrade to 3.11.4.1 solves the problem, each time we had the same problem when AP was on 3.11.3 or 3.11.3.1 dont remeber exact what fw version was…
I had this problem on 3.11.3-r7
I changed the PER sample rate to 10 and it syncs now.
