Getting the following when trying to import a config file via the GUI.
5.7 - 450 AP with 13.3
Info: Variable regionCode reported error 3
Configuration file "filename.cfg" triggered from web GUI, failed to import
Anyone know of a way around this?
We recently discovered and fixed this bug. The fix will be in R13.4 (Beta for this release should become available very shortly).
In the meantime, the workaround is to remove the RegionCode line from the config file. Then it should import correctly, but will require you to manually set the Region in the AP.
Matt
