Hello All,
Is there any way I can edit the ethernet frame size on a PTP54500 radio?
Hi Julius
Not on the PTP radio itself - The radio will just bridge all the frames it receives, and retransmit them as they are received. So you will need to change the frame size on the units that are originating the frames.
The units support multiple frame sizes
Regards
Julian
