I have one R200p configured as WAN IP mode PPPoE. The WLAN works perfect and when I make a speedtest, the throughput is arround 80Mbps downlink and 30 Mbps uplink, that are the values expected taking into account my connection.
However, when I make the same test directly connected to the ethernet LAN ports of the units, the maximum throughput is lower than 500kbps. We have made the same test with several laptops.
The firmware version is the latest 4.3.1 software.
why I have to configure a VLAN?. The VLAN mode is disabled because I need that the WAN port data arrives to this interface as untagged. I receive the PPPoE perfectly and I can navigate using WLAN. Which is the different between WLAN and ethernet LAN interfaces in this case? The behaviour of the WAN should be the same in both situations...
I have tried with the same WAN interface configuration like yours with single management-internet-voice profile in PPPoE mode and VLAN mode disabled. I'm getting good speed on LAN side with downlink and uplink.
Can you please share your device config file, so that i can load that and check.
Hi We did not see speed test issue with your attached configuration(Device Firmware Details : 4.3.1-R1201612201723) It seems there is issue with Ethernet interface of device. To verify Ethernet Lan issues, Please run speed test on another R200 device with your configuration or run LAN throughput test as per below procedures. Procedure to run LAN throughput test. 1. Configure device in default mode. 2. Connect two LAN PCs to Ethernet interface of device. 3. Run Iperf traffic test in between two LAN PCs. Note: I have attached the network diagram for LAN throughput test.
I´m making test with your R200p unit. The throughput for the download speed is much lower than the expected value. However, for the upload speed the throughput is perfect (arround 90Mbps).
I have made several test, connected to the ethernet LAN port and to the WLAN SSID. With WLAN, works better, but I only have 25Mbps in a 100Mbps Internet connection. For the ethernet LAN is even worst (lower than 1Mbps). We have tested it with several laptops and we have allways the same resutls.
The unit has the 4.3.1 firmware version and the only configuration different from the default is that I have configure PPPoE and the account.
I have tested exactly the same internet connection with a different Router (DLINK) and it works perfect (90Mbps for download and 90Mbps for upload).
Hi Nilesh, it is pretty much the exact same issue, on the latest firmware version and we have an open case going. You can PM or email me for the details.
