Esakki
(Esakki)
#1
This Esakki, We used 6 pair of PTP650 Connectorized ODU.
I have a issue in recenty deployed ODU which is the PSU Port not connect by 1000 Mbps.
I used Cat5e cable the length of 75 Mtr.
I checked with LAN Tester the cable connected all 4 pairs correctly.
Please guide me.
Regards,
K.Esakki
Hi Esakki,
You could use the cable diagnostics feature in PTP 650. See the web page like this:
Also, you should check the Ethernet settings at both sides of the link. The safest option is Autonegotiate like this:
Check that the connected switch or router has the same configuration.
Mark
