Hello
Kindly advise the configuration I should use for a F200 link to deliver E1 services to a client.
An E1/T1 is known as Primary Rate Interface (PRI), is an Integrated Services Digital Network (ISDN) access method. None of the ePMP products provides a native PRI interface, so you’ll need to use a modular router on both sides that supports both PRI and ethernet interfaces. You’d connect the E1 to the PRI interface on the router, and the F200 on the ethernet interface on the router, and then configure the router to bridge/translate the traffic between the two mediums.
