F200L reset
Why does F200L reset yet the option of reset by power squence already is disabled also when ever am using version of 4.7+ Sm status first shows Rejected ina response
Hello @Jane_Katassi,
If I understand correctly, you are experiencing two separate issues:
  1. The F200L resets its configuration even when “Reset by Power Sequence” is disabled.
  2. On firmware versions above 4.7.0, the device is unable to connect to an AP, with the reason reported as “INA retries exhausted.”
Could you please confirm whether the F200L is able to connect to the AP when using firmware version 4.6.2 (for example)?
Additionally, could you confirm whether both issues occur on the same unit?
Thank you!
When i have seen many F200L Resetting by power and my question is why should they reset yet reset by power squence is already disabled and also can you please add an option of keep alive in cambium when sm is configured in NAT or its the same with watch dog
Remember we can only use 4.7+ version on F200L but why does it reset
