Não consigo usar a faixa de ip 192.168.0.x ,alguem sabe porque? Alguem já pasou por esse problema?
I can not use the IP range 192.168.0.x, anyone know why? Someone already pasou by this problem?
- erro ip.JPG (45.2 KB)
Hello,
The 192.168.0.X/24 subnet is reserved as the default network for ePMP devices. The DHCP server in the radio won't allow you to use this network for your local LAN. As an alternative, you could use, for example, 10.1.1.X/24 or 192.168.1.X/24.
Hope that helps.
