I need to know if i installed a 2 ft feed horn(Model HPD2 5.2NS) with a 4 ft parabolic reflector(SPD4), what will be the reult?
will it work fine?
will it work fine?
Can you be a bit more specific as to what you're trying to accomplish? Are you using this 2 foot dish on one side of a link and the 4 foot dish on the other side? What radios are you using? What is your link distance? What is the maximum EIRP/TX power allowed in your region?
We need more information in order to answer this question.
