Hello,
One of my techs accidentally installed an Advantage 5750 SM on a customers house over the past month.
Is there a way in Prizm 3.0/3.1 to do a search specifically for Advantage SMs?
Thanks for any help that you can offer!
-Mike
There isn’t really a way, you can log into any new SM’s you installed in the last week and check the QOS tab. If it goes past 7mb then that’s your advantage unit.
If you know where the past month’s installations were done at you could simply log into the APs and check the sessions page. On my 8.x stuff it tells me if it’s a Lite SM or not. If your AP hasn’t rebooted in a while then the SMs installed most recently will be towards the bottom of the list.
