First configuration
Hi, I can not connect to SM.
I have the device you recommended with IP 192.168.1.254 that releases an IP with DHCP.
When in the CNArcher application I have to select the WiFi network and the antenna IP, it fails, error.
With the smartphone, in chrome, i can enter in the GUI! Why does the application fail?
In the app i selected No in "Do you use Maestro?"
Solution:
"Please go to Android's Wi-Fi settings screen and "forget" the SSID you use for install. Then start the app, go to "Settings > Wi-Fi"  and connect again to the same SSID. "
