I've got a pair of preconfigured Force 180 devices, Firmware 3.2, later upgraded to 3.2.2.
During testing I configured one of these to Radio Mode "Access Point", Driver Mode "Standard Wifi" and WLAN enabled, alternatively disabled. Management ID has changed to a static IP address and I connected it to my local LAN. Frequencies have been set manually around 5560 Mhz, 40 MHz channel width.
I used a tablet, configured SSID and password and could connect to the WiFi network, but didn't get an IP address from the DHCP server in the wired LAN. So I gave the tablet a fixed IP address and configured DNS and gateway manually.
However, I was not able to connect to my local LAN through the Force 180. Radio link is stable over short and long distances, but no data traffic possible.
When the Access Point Mode is set to Standard WiFi, configure this parameter: Enabled: The ePMP AP operates as a WLAN device and allows any 802.11 client to connect to it within a 1000meters radius. Disabled: The ePMP AP operates in Standard WiFi mode to allow outdoor 802.11n clients to connect to it at longer distances. This mode is typically used to migrate non-Cambium SMs deployed at longer distances to ePMP SMs.
Could you please clarify whether you have issue with traffic with you tablet or Force 180 running in SM mode?
Yes, I did. But there seems to be no communication between the Force 180 and the tablet. The Ping utility in the Force GUI is able to ping into my LAN, but when I ping the tablet I get no answer.
Well, after a support session it turned out that 40 MHz channel bandwith didn't work not with my standard wifi devices. AFAIK I had tested 20 MHz bandwith, too. But I am not sure and also it is possible that I used a wrong channel setting when I tested 20 MHz setting.
However - everything works fine and thanks Fedor for the quick and professional help!
Hi, i have veen using tplink to connect to ap around me(including my phone), i drcided to get the cambium force 180 and it has really frustrated me cause i cant seem to understand how to connect to any ap around me
Hello everyone! I did the necessary configurations, but I still can’t connect any device except for an SM, since other 802.11n clients I can’t see the SSID and much less connect. There is someone that can provide some configuration guide or similar? Regards, JC.
to add to this for anyone else who plans to connect standard N devices to these radios.
these radios can use channels that are not within the standard ranges on N spec. BE SURE to select a channel that is considered a standard channel otherwise devices like phones and computers will not see it.
other radios like cambium devices will be able to find them, but only devices that are designed to fully use the band.
