We installed ePMP2000 recently and Force 200. Both working fine on v3.5. Yesteday we upgraded both to 4.4 and the Force started connecting and disconnecting continuoly from the epmp2000.
Some others are working though .....any help what could be the problem
Are you running a mix of 3.5.6 and 4.4? I'd highly recommend that you run either 3.5.6 on everything (ap and SM's) or 4.4 on everything (ap and SM's)... DO NOT MIX! There are some bugs when running mixed firmware that are being worked out hopefully for 4.4.1.
