Good afternoon, could you help me with the following problem? The capacity does not increase. The distance is 18 km. The signal is good. I can change the frequencies but nothing in advance. Thank you.
sorry i used google translate
Hello,
What Firmware version?
What do your chains show in eAlign?
What does your Spectrum show in SA?
Normally, you’d have much better modulations than DS3 with a -54 signal. SNR of 34 is ok-ish
thanks for the i change the chanel but still the problem
with 6030 this is the best. So I think I’ll leave it at that.
