hi, i am currently having a little problem with cambium force 180 and epmp1000,
the force 180 has a reading of rssi and snr, -68dBm and 37dB respectively. but the link quality(uplink) and link capacity(uplink) is 0% (highlight with red). this two will have a percentage for about five seconds, then will go back to 0%. when it goes back to 0%, the rssi and snr will drop to -97dBm and 0dB respectively, and then goes back to the proper reading (-68 and 37). the ap is located at the roofdeck of the building, there are a lot of unknown antennas and odu, the downtilt is 45degrees and the distance is 106. the los is clear. anyone had the same problem? thank you. :)
From what you described, it appears that the Force 180 may be disconnecting and reconnecting to the AP. Repeating Eric's question, what release are you running? Also, have you had a chance to run Spectrum Analyzer and Tools -> eDetect yet?
